Hello to all, just wanted to check, does my solution work for you, or are you still facing same issues Please contact me if you need any help, I will be happy to help you here.
@infofcc3 The problem isn’t so much about how to do the task itself, but rather how to automate the process for other users. Clicking this option a few times is easy, but add multiple users and constant calls to export and we can be sure that some will forget to do so.
As of today, this issue seems unresolved since the linked GitHub discussion seems dead.
Thank you for your input. I agree that the challenge isn’t necessarily the task itself, but rather the automation of the process for multiple users. While performing the task manually a few times is manageable, the issue arises when dealing with a large number of users and frequent export calls, as it’s likely some may overlook it.
As of now, it seems this issue remains unresolved, especially considering the inactivity in the linked GitHub discussion.
