How to download CSV from grafana
Steps to download csv from grafana
Step 1. Go to your grafana dashboard and select the data from your data source.
Step 2. Now add thresholds as per your requirement.
And now save it
Step 3. Click on panel menu and > inspect > data
Step 4. You can see the side bar now click on Data options and expand the section.
Step 5. Check apply panel transformation and download csv now your transformation column also added to your csv.
Final Outcome: -
