Export to CSV, set default value of Apply Transformations as True
Is there any way we can set the below option to true when exporting the csv data.
I have checked the setting options, but there is nothing in there related to this.
I have also checked some of the script files in Grafana installation directory.
In the InspectDataOptions.tsx file I can see it is pointing and getting some inputs from ‘@grafana/data’.
But I am not sure where and which file this is referring to.
Any inputs would be very helpful.
Thanks and Regards,
Bhushan
