API to generate CSV File
I was wondering if there is an endpoint to generate the CSV file from a graph in Grafana. I want to automatically produce this report if possible. Is there anything like that with Grafana already? If not, how do I request that feature? Thanks.
There is currently no API endpoint for exporting panel data as a CSV file.
The CSV export function is implemented in JavaScript/TypeScript on the frontend so to expose it in the API, it would need to be implemented on the backend and would only work for data sources that have a backend written in Go. So it is not as simple as it might seem to implement this.
You can create a Feature Request issue (just prefix the title with [Feature Request]) in the Grafana GitHub repository and if there is enough interest then we will build it.
I opened feature request #8667 Maybe I can generate some interest.
It was closed on June 2017 with the promise to implement feature around 2018
Still no progress in 2019
torkelo commented [on Jun 21, 2017]
dashboards & panels are UI constructs, so to automate them it would have to involve a browser so this is not easy to do.
We hope to introduce a fully featured reporting (PDF/CSV most likely) feature next year.
https://github.com/torkelo closed this [on Jun 21, 2017]
That is UI, do they have API for it?
