It’s only been a few weeks since I started to use Grafana with Prometheus and I’m trying to create reports with grafana. I have seen that you can create CSV files with the graph panel (http://docs.grafana.org/reference/sharing/#embed-panel)
But I need to generate the data for every 1 or 2 minutes and if I generate a CSV file with a time less than 1 month, it’s ok but for 1 year, the data generated is by part of 6 hours.
How can I generate 1 CSV file for more than 1 month by parts of 1 minute ?
And do you know if in a future release, we will be able to export csv file with the singlestat panel like we do with the graph panel (just to make a % of the availability of a server) ?
Thanks for you help
