Disable CSV option in panels
Hi , Please someone can tell me is there any option for disabling “CSV” from panels.
Saw that you also posted on CSV Export depending on user role
The answer is still the same. We have no plans to implement such a feature as it is fake security - anyone can get the same data by opening the Chrome dev tools and examining the http response.
Of course, Grafana is open source so it is probably not so hard to implement yourself if you know any front end programming.
There are some other options when it comes to security. Using the permissions system, you can remove access to sensitive dashboards. Grafana Enterprise has some extra permissions for Grafana datasources.
Got it. Thanks a lot for your quick reply.
