I have set up visualization panel that display three different process values as timeseries. All values are of the same type and the same range. When I go to Inspect->Data I have option to download csv, but the default option is to download only the first process value. Every time I need to go to data options to set “Series joined by time”.
Is there any way to set that as a default option?
Thank you!
