XY Chart Adjust X axis max
    v10.0.2 free version, Ubuntu.
    Adjust the X axis on a XY chart panel to show a greater range so that values on the edge are not almost off the chart.
    I attempted using the axis max and min overrides to have different values for the x and y axis. them to match there.
  • What happened?
    The overrides on the y-axis work, the max and min are set properly there, but the x axis completely ignores the settings.
Nothing I do seems to get it to show a wider range, any advice would be appreciated, currently the scale can make it extremely unclear when on small time settings due to the points all being at the edge.
Hi - Similar problem with 10.0.3. A plot with only 2 x-axis values doesn’t display well because the points are right on the edge. Could you please add some default padding on the x-axis width?
Also - my x values are integers and while I can turn decimals off, I can’t currently find a way to restrict the axis to only show integer values. Thanks.
