Adjust Y axis steps
I’m pretty sure that I have been able to set Y axis steps in Grafana in the past. Now I just spun up a new version 8 instance and it seems impossible to tweak the Y axis except for min/max. Is this correct or am I just a clown?
So, I have this new Grafana 8 “Time series” showing number of automated builds a given day. This is will always integer numbers in the range of 0 to 5 or something. Problem is that the Y scale in the graph shows fractions and that is really not that relevant and clutters the graph.
I have included a screenshot.
Please tell me this can be adjusted in latest Grafana :wink:
How you solved this issue?
