hello Evryone
i have a problem with changing y axis in grafana 8.5 . y axis does not change to desire units like bytes .
grafana oss version = 8.5
os version = Redhat Entrprise linux 8.5 -
change y axis to byte unit -
change axis part for kilobits/sec -
What happened?
y axis does not change and still percent for bandwidth utilization get from zabbix data source -
units change to kilobits/sec for data rate -
“id”: 2,
“gridPos”: {
“h”: 8,
“w”: 12,
“x”: 0,
“y”: 0
“type”: “graph”,
“title”: “--------------”,
“datasource”: {
“uid”: “Jl907Il7z”,
“type”: “alexanderzobnin-zabbix-datasource”
“thresholds”: ,
“pluginVersion”: “8.5.0”,
“description”: “111”,
“legend”: {
“avg”: false,
“current”: false,
“max”: false,
“min”: false,
“show”: true,
“total”: false,
“values”: false,
“hideEmpty”: false,
“hideZero”: false
“aliasColors”: {
“--------------------------------------”: “semi-dark-blue”,
“-------------------------------------------------”: “blue”,
“bytes(SI)”: “blue”
“dashLength”: 10,
“fill”: 2,
“fillGradient”: 8,
“lines”: true,
“linewidth”: 1,
“nullPointMode”: “null”,
“options”: {
“alertThreshold”: true
“pointradius”: 2,
“renderer”: “flot”,
“seriesOverrides”: ,
“spaceLength”: 10,
“targets”: [
“application”: {
“filter”: “Interfaces”
“datasource”: {
“type”: “alexanderzobnin-zabbix-datasource”,
“uid”: “Jl907Il7z”
“functions”: ,
“group”: {
“filter”: “WAN”
“host”: {
“filter”: “------------------”
“item”: {
“filter”: “-------------------------------------”
“itemTag”: {
“filter”: “Application: Interfaces”
“options”: {
“disableDataAlignment”: false,
“showDisabledItems”: false,
“skipEmptyValues”: false,
“useZabbixValueMapping”: false,
“minSeverity”: 0,
“sortProblems”: “default”,
“acknowledged”: 2,
“hostsInMaintenance”: false,
“hostProxy”: false,
“limit”: 1001
“proxy”: {
“filter”: “”
“queryType”: “0”,
“refId”: “A”,
“resultFormat”: “time_series”,
“table”: {
“tags”: {
“filter”: “”
“trigger”: {
“filter”: “”
“triggers”: {
“acknowledged”: 2,
“count”: true,
“minSeverity”: 3
“slaInterval”: “auto”,
“slaProperty”: {
“name”: “OK time”,
“property”: “okTime”
“itServiceFilter”: “Uptime SLA”,
“showProblems”: “problems”
“timeRegions”: ,
“tooltip”: {
“shared”: true,
“sort”: 0,
“value_type”: “individual”
“transparent”: true,
“xaxis”: {
“mode”: “time”,
“show”: true,
“values”: ,
“name”: null,
“buckets”: null
“yaxes”: [
“format”: “percent”,
“logBase”: 1,
“show”: true,
“$$hashKey”: “object:305”
“format”: “short”,
“logBase”: 1,
“show”: true,
“$$hashKey”: “object:306”
“yaxis”: {
“align”: false,
“alignLevel”: 0
“bars”: false,
“dashes”: false,
“hiddenSeries”: false,
“percentage”: false,
“points”: false,
“stack”: false,
“steppedLine”: false,
“timeFrom”: null,
“timeShift”: null,
“decimals”: 0
do not get error in grafana UI and grafana log
please help me for resloving this issue.
thanks in advanced .
