v8.3.1 (8d38082755) Windows 10 -
I’d like to set the max value of the y axis but let it adjust if all points are lower.
Suppose I set the y max to 10, and the data points are [4,5,2].
At present, the panel scales to 10, regardless of the data.
I would like the axis to, in this situation, adjust to something close to 5. If there was a data point above 10, then it would remain at 10.
In a sense this is the inverse of the current soft max, which adjusts only if the values are higher than the defined max value. -
I’m not sure this is possible. -
What happened?
N/A -
As explained above. -
N/A -
No -
No
I think you might want to experiment with the config from query results transformation:
Thank you for your reply, Matt.
I had already looked into this option (should have mentioned in the initial post), but my query uses regex to find any matching (InfluxDB) measurements, and within that regex is a variable that’s used for repeating panels. This essentially:
where panels repeat according to EfflParamGrabComp.
This means that in practice, each repeating panel will have a varying number of series, and they will have different names. What I see from Config from query results is that it requires that I specify in advance exactly how which field will be used, which is not possible for repeating panels.
Another point is that, even if the above was possible, I couldn’t find a way of implementing the condition of having the max value of given query be used as the y-max only if this value is below a threshold.
Perhaps I am missing something?
