Hello all,
I am using Grafana version v10.0.1 and I want to show the values on Y-Axis of my Time Series Panel so the smaller values are at the top and the larger values at the bottom.
I have searched the forums, but couldn’t find a solution to my problem.
Can anyone help me to invert Time Series Panel graphs in Grafana so smaller values are higher on the Y-Axis?
I found 2 half solutions to the problem, but both cause the Y-axis values to be shown as negative numbers which I want to solve.
The first solution is multiplying the query result with -1, while the second solution is using a an Override property for Graph styles Transform for all values fields and setting the Negative Y value as shown in the picture below.
Thank you
