Is it possible to flip the axes on an XY chart?
Hi, I have an XY Chart that I want to flip the X axis on, so that instead of ascending values it would display descending values. Is is possible to do that?
For Time Series it is possible to use Overrides - Graph styles > Transform - Negative Y:
For XY Chart, Transform is also mentioned in the documentation, but I haven’t seen that it is already available.
So as of now for XY Chart I think it is possible only at datasource level…
you might want to look at business chart plugin
try it in grafana using this for Business Chart plugin
return {
  xAxis: {
    type: 'category',
    inverse: true,
    data: ['A', 'B', 'C', 'D', 'E', 'F', 'G']
  yAxis: {
    type: 'value'
  series: [
      data: [150, 230, 224, 218, 135, 147, 260],
      type: 'line'
Thank you, both of you!
I ended up going with the plotly plugin in the end. It seems fairly similar to Business Charts.
Plotly plugin for Grafana | Grafana Labs
