I am using Managed grafana -
I need time in Xaxis ,but my data contains both time and date “2024-06-14 01:09:11.883000000”,I need only time in x-axis in timeseries chart -
What happened?
I am getting date in x-axis instead of time -
I need time in x-axis
Use XY-chart and override unit of X axis as time:HH:mm, converting time to number via transformation:
Thank you so much for your reply @ebabeshko
but it does not shown time in x-axis even after done those things that you have mentioned above.
