Hello Forum,
As you can see on the picture, I want to display the electrical power from my solarsystem in kwh. It works fine but I can’t change the X Axis lable. I just want to see the days not the time.
Thanks in advance.
From Grafana documentation:
time:<format>Custom date time formats type, such astime:YYYY-MM-DD. Refer to formats for the format syntax and options.
Thanks! That was the problem. Thanks.
