How to format X axis label
I use Grafana v9.3.2 on a Windows Server 2016.
I have a barchart but problems with the X-axis label:
time range 7 days:
XAxisLabel1
time range 2 days:
XAxisLabel2
I always want to show the date in format like:
DD.MM.YYYY
independent from the choosen range.
I looked here in the forum but could not find any solution.
I found only that one can edit the general date format inside defaults.ini.
But this does not solve my problem.
So how please can I format the x-axis labes to my needs?
Hi - is here any solution available please?
may someone from Grafana team can assist here please?
Hi @mrburns,
Take a look at this post:
Links:
Best regards,
ldrascic
The word “solution” is only a terrible workaround which is only working in 5 % of the cases.
This program is so super complicated to use. The UI is so really badly done. It is extremely frustrating how much time I am loosing fiddling around in some settings in some config files.
The UI needs a totally new approach from the user’s point of view but not from the developer’s perspective who only uses the command line and never uses the Web UI.
Hi @martinklimke,
Date formatting now works on time series too! Tested on Grafana 10.1.5.
Best regards,
Ldrascic
Solution does not work for me…
Trying to do similar stuff… have a time series, shows values as bars.
Using the override-trick as shown here does not do any change to the timeformat on the x axis, sticks to default. Would like to have something like “DD HH:MM”, but whatever i choose, there is no difference.
The query to create the data:
SELECT
ts as time,
price/1000*100 as “Preis in Cent”
FROM misc.aWATTar
WHERE ts >= $__unixEpochFrom() * 1000 AND ts <= $__unixEpochTo() * 1000
ORDER BY ts ASC
Is there an update on this?
It would be really helpful to be able to easily switch the display of date/time on the X-Axis to a user defined format
Still not working.
+1 for this request, it’d be really useful
