v9.3.6
I want to display short date on chart X-Axis
I don’t know
What happened?
Nothing
A short date formatting according to DD/MM and not MM/DD
How to format a date into the X-Axis ?
Hi @swiftice3253,
Welcome to the
community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community
What is your DataSource e.g. Prometheus, InfluxDB, MySQL etc?
You can use the Override function to change the Time format.
I attached a screencast (open it in a new window as will be easier to zoom in and view more clearly)
I hope this helps.
This only changes the tooltip in status history, for instance. It doesn’t change the x-axis.
