What Grafana version and what operating system are you using? 10.3.1 on Win 10
What are you trying to achieve? Trying to change the displayed time on the X axis from continuous 00:00’s to mm/dd with one per day.
How are you trying to achieve it? Using a Transform
What happened? Cannot get the format I wanted.
What did you expect to happen? An X-axis with days as MM/DD
Can you copy/paste the configuration(s) that you are having problems with? Done
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. None.
I have two queries producing two values PV1 and PV2 on the same time range.
I want a bar chart of PV1 & PV2 as a side-by-side bar-chart vs days. The time series bar chart only offers a stacked option hence my choice of the bar chart.
The Bar Chart produces the display I want perfectly but the X-axis shows each day as the midnight time 00:00. I can rotate the times so they are readable but what I really want is the date as MM/DD.
Here is the panel:
I tried to change the X Axis field but “Time” is the only offering or “First string”.
I have also tried “Convert field type” which does not seem the right one to use.
If I look at the data in the table the timestamps are complete. I cannot see why they are not displayable. Here is the table:
I am so close to what I want the chart to be and cannot see why the X-axis stubbornly remains with the midnight time. If I change the Group By to a smaller interval like 12hours then the graph is still correct but still only shows the times.
What is the solution please?
