I wanted to change how the x-axis is displayed. Change the way the dates are displayed in dd/mm/time to just the day of the week
Hi @nivekc Try the override of the units to be time:dd ( you will have to type it in, as it is not in the list of choices).
Unfortunately, I have found it only works (for me) on tables. Maybe one of the Grafana staff can comment on if it should not work on other visualizations.
Thanks Grant, Iāve been playing around trying to get this to work for a fair while.
@grant2, Thank you so much for taking your time on this. I tried your solution and yes it only works when I change it to a table. But on trying to implement it on the visualization, it reverts back to the day and time format.
@anon70503803 @anon80964540 or anyone at Grafana: Can anyone comment on if the day of week time format should work on other visualizations (besides Table, where it works fine)?
Iāve brought this to the teams to double check, but Iām fairly sure there isnāt a way to adjust the appearance of the time on the x-axis with the time-series panel.
You can use strings on the x-axis for the bar chart, not bar gauge, so I was able to duplicate this table and, without changing anything, it worked OK for bar chartā¦maybe?
https://play.grafana.org/d/_ovpFVYnz/day-of-week-test?orgId=1
the tooltip in the timeseries displays the day of week, but not the x-axis.
I even tried overriding GF_DATE_FORMATS_FULL_DATE=āDDDD HH:mm:ssā. Interestingly, that gives the day of the YEAR. This shows on the tooltip, and the date-picker, but has no impact on the x-axis in the time-series, alasā¦
might be a worthy feature request?
@anon70503803
Yes, for bar charts it works just fine. The limitation comes in the time series.
Yes, I think it might be worth a feature request. Thanks.
Hi grant2, I have a little bit the similar problem, but I want to add to X axis just DD/YYYY. Do you have any idea ? This is what I have now
Hi Bartosz,
AFAIK, there isnāt a way to adjust the appearance of the time on the x-axis with the time-series panel.
try to use:
time:DD/YYYY
It works on Grafana 9.4.3
capital letters had to be used
thanks Guys
where did you make this change , I tried using transform but itās not working thereā¦
@ankurnigam: you need to use an āoverrideā to override the standard settings.
For example, in my case:
(see the āOverride 2ā)
I hope it helps.
Ciao
I am still on Grafana 7 (7.5.17) as it is hosted by a third party. I am trying to achieve the same. In v7, the new bar chart is not available yet, only the āBar Gaugeā and the āGraphā which can be used with bars.
I tried to add the overrides mentioned in the comments here, but without success. There even is an override format called āDaysā, but this also does not change the display on the X-Axis nor the hover tooltip.
Did anyone achieve this using these āoldā Visualisations?
Thanks & best regards
Philipp
modify server config file : grafana.ini or defaults.ini
ddd means weekļ¼you can modify interval_day = ddd MM/DD
[date_formats]
interval_second = HH:mm:ss
interval_minute = HH:mm
interval_hour = MM/DD HH:mm
interval_month = YYYY-MM
interval_year = YYYY
