Can we swap the X and Y axis for line chart? In other words, when there is time on the y axis, there is a value on the x axis.
Maybe? It looks like some of the options in the X-axis settings might do the trick. https://grafana.com/docs/grafana/latest/panels/visualizations/graph-panel/#axes
Thank you for answers. I solved this problem by using the “Plotly” plugin.
Which Plotly plugin did you go with? (There are two of them as of this writing).
Plot.ly plugin : https://grafana.com/grafana/plugins/natel-plotly-panel
