latest version -
Multi user access to the application -
Using open source version installed on Azure App service -
What happened?
Not able to handle more than 7 concurrent users -
There should not be any limit for concurrent user access -
No -
Username and Password incorrect -
Did you configure proper database for Grafana? Default sqlite is convenient for easy start, but it is file based and may have a problem with concurrent access.
Otherwise only used hardware is your limit.
ok thanks for the reply. I will check this , but as a production ready application can we go with default SQLite DB or shall replace it with postgresql DB?
That’s your call. Are you ready to loose Grafana DB? If yes, because you have everything automated and you can provision new Grafana instance and configs/dashboards in minute, then probably yes.
But that’s not a case for majority of Grafana deployements. Then you will benefit from serious DB (concurrent access, backup tools, replication).
With SQLite, because of how the file-based database works, when you have lots of users you can run into issues where the database is both trying to read and write at the same time, and lock errors result. SQLite is a good easy option for starting out, but if you plan to have lots of users, a general database like mysql and postgresql is a better choice because they run many concurrent transactions and don’t have the file-based locking issue.
Generally with OSS Grafana we start out with sqlite because it’s so simple and doesn’t involve complex additional dependency setup when users are just getting started kicking the tires.
You can read more about the file based locking issue here. Some possibly useful tools/instructions for migrating to postgresql can be found here
thanks a lot for providing quick support.
