I have Grafana running on Docker with InfluxDB.
And often the section closes without explanation.
And then it takes a few minutes to log in.
The error that appears in the terminal is as follows:
I guess you are using default sqlite database, which is not the best for concurrent access. Use more suitable database for your Grafana instance, e. g. MySQL, PostreSQL Configuration | Grafana documentation
Hi Jangaraj.
I’m using Influxdb database, is it the same problem?
@jangaraj is referring to Grafana’s backend configuration database:
Good afternoon.
If Grafana is running on Docker, is the procedure below valid?
