Grafana: 7.3.4
OS: on azure Kubernetes -
Have Grafana display the results from the DataSource in a timely manner for 50+ concurrent users. -
2 server instances of Grafana are deployed, either postgres or mysql used for database (also deployed on azure Kubernetes), and a single API functioning as the DataSource (also in azure Kubernetes). -
What happened?
Recreating a dashboard and refresh time of 5 seconds on JMeter and simulating 50 concurrent users lead to the conclusion that Grafana cannot handle the load.
Isolating the API proved that it could handle the load.
First problem was the CPU usage, a single instance of Grafana quickly capped the assigned 2core node. Adding a second instance in a different node brought the CPU usage to reasonable levels, but times to answer the requests were still too high.
After turning on multiple log options on the config, the second problem was suspected to be the database, as the response time for requests increased, so did the time to query the database. Both Postgres and Mysql databases where tried, however both produced similar results, with high response times. (Results of a test can be observed in image1)
image1: test with loadBalancer > 2 grafanas > loadbalancer > 2 Mysql databases
Grafana to be able to concurrently handle the load of 50 users. This means maintaining the utilized dashboard of ~~10 panels with a refresh rate of 5 seconds for each user. -
I do not believe I have problems with the configuration. Everything is working fine except that Grafana is not able to handle 50 users at the same time.
however here are the changed configs (via yaml):
env:
- name: GF_LOG_LEVEL
value: debug
- name: GF_LOG_MODE
value: file
- name: GF_PATHS_LOGS
value: /var/lib/grafana/log
- name: GF_DATAPROXY_LOGGING
value: ‘true’
- name: GF_LOG_FRONTEND_ENABLED
value: ‘true’
- name: GF_SERVER_ROUTER_LOGGING
value: ‘true’
- name: GF_DATABASE_LOG_QUERIES
value: ‘true’
- name: GF_AUTH_TOKEN_ROTATION_INTERVAL_MINUTES
value: ‘1000’
- name: GF_SERVER_DOMAIN
value: -domain-
- name: GF_SERVER_ROOT_URL
value: https://%(domain)s/grafana
- name: GF_INSTALL_PLUGINS
value: >-
-custom pluggin to comunicate with API-;onecc-plugin,https://grafana.com/api/plugins/grafana-piechart-panel/versions/latest/download;grafana-piechart-panel
- name: GF_AUTH_GENERIC_OAUTH_ENABLED
value: ‘true’
- name: GF_AUTH_GENERIC_OAUTH_TLS_SKIP_VERIFY_INSECURE
value: ‘true’
- name: GF_AUTH_GENERIC_OAUTH_CLIENT_ID
value: -client id-
- name: GF_AUTH_GENERIC_OAUTH_CLIENT_SECRET
value: -client secret-
- name: GF_AUTH_GENERIC_OAUTH_EMAIL_ATTRIBUTE_PATH
value: sub
- name: GF_AUTH_GENERIC_OAUTH_AUTH_URL
value: -link-
- name: GF_AUTH_GENERIC_OAUTH_TOKEN_URL
value: -link-
- name: GF_AUTH_GENERIC_OAUTH_API_URL
value: -link-
- name: GF_AUTH_GENERIC_OAUTH_AUTHORITY_URL
value: -link-
- name: GF_AUTH_GENERIC_OAUTH_SCOPES
value: openid profile datastudio_api offline_access
- name: GF_AUTH_SIGNOUT_REDIRECT_URL
value: -link-
- name: GF_AUTH_OAUTH_STATE_COOKIE_MAX_AGE
value: ‘60000’
value: ‘1000’
- name: GF_DATABASE_TYPE
value: mysql
- name: GF_DATABASE_HOST
value: -ip-:-port-
- name: GF_DATABASE_USER
valueFrom:
secretKeyRef:
key: username
- name: GF_DATABASE_PASSWORD
valueFrom:
secretKeyRef:
key: password
- name: GF_DATABASE_MAX_IDLE_CONN
value: ‘70’
- name: GF_DATABASE_MAX_OPEN_CONN
value: ‘70’ -
Throughout the experiments made, some errors were encountered, but some tweaking of the configs solved them. (An example is a problem where Grafana would create too many connections with the database, solved by configuring “GF_DATABASE_MAX_OPEN_CONN”) -
Did not follow any online instructions in particular for configuring Grafana.
