Visuals change size after exiting edit mode
Hi all, looking for some guidance on dashboarding. I’m seeing Grafana change the size of my graphs when I exit from ‘edit’ mode. In this image, all 4 graphs are supposed to be the same size (the bigger size), but this is how it looks when I exit ‘edit’ mode. Anyone know why Grafana changes the size of the visuals between edit mode and non-edit mode?
Grafana has “responsive” design, so it optimizes panel size based on view. You have only one panel in the “view” in the edit mode, so size is different. Just change panel size in non-edit mode as you need.
Is there a way to lock the size? For my end users, it isn’t ideal for them to have to change it (and most of them won’t know how to or that they need to).
No, what’s a problem?
You edit size in non-edit mode, you go to edit, then again to non-edit and size will be again the same.
I’m not able to edit size in non-edit mode. There is not that icon in the lower right. Could you please share how to do that?
