Grafana v10.0.1 (5a30620b85) running in Docker on Unraid.
- What are you trying to achieve?
Show a rendered image of a dashboard panel at different size than 1000,500
- How are you trying to achieve it?
Set height
and width
in the URL query parameters to a different value than what the ‘Share’ dialog uses by default.
- What happened?
In the scaled-down version (500,250
instead of 1000,500
), the Y-Axis only ranges from 4 to -4, rather than 6 to -8.
And in this second example, where I also change the aspect ratio (size is 350,300
), the data itself looks noticeably different, too (notice the absence of that big peak).
I’d expect the graph to scale properly, like they do in a dashboard. There I can resize each panel without distorting the Y-Axis or the data.
- Can you copy/paste the configuration(s) that you are having problems with?
Running grafana/grafana-image-renderer:latest
and grafana:latest
, with GF_RENDERING_CALLBACK_URL
and GF_RENDERING_SERVER_URL
set appropriately. The renderer is otherwise running a default configuration.
- Did you follow any online instructions? If so, what is the URL?
