Visualization problem with dashboard Bar Gauge v11.1
-Grafana v11.1.0
I´m trying to visualizate this class or dashboards (bar gauge), but with the v11.1 it chanegs a lot, and i can´t see my numbers.
I changed the bar size to manual, and try differents numbers: in this case i used, min 0 max 20, but depend de large size of the dashboard i can see the numbers or not.
Could you help me, please?
Increase width of your panels
But i need to have this size, the other size it´s too big for my idea of panel
So decrease size of page in the browser (CTRL + - usually) :person_shrugging:
Yes, that is a solution, but if I put the panel on the laptop screen and an external screen some dashboards are seen and others are not. Is there a way to set the panel size fixed?
Is it really good idea? How it should work if you load that dasbhboard with fixed panel size (e. g. 500px) on 6’’ - 64’’ screen?
