My intention is to see my painel Indice de Dashboards less than be presented on my screen -
I am looking for some option that make it possibel but I didn’t find anythin. -
What happened?
The screen is very poluted. -
receive on how I can see my panel dashboard more friendly. -
my current page is
I would see this panel as the other that is ok.
No, I did not receive any erros.
The purpose is only to leve my panel friendly as I need. -
I did not find any help to achieve it.
