If this option does not work then you can tell us if you have another option.
“datasource”: {
“type”: “mssql”,
“uid”: “b725e3d2-d13d-431c-aa26-cd343ca33b91”
“gridPos”: {
“h”: 8,
“w”: 12,
“x”: 0,
“y”: 0
“id”: 1,
“maxPerRow”: 60,
“options”: {
“nodes”: {
“arcs”: [
“color”: “#73BF69”,
“field”: “arc__cpu”
“color”: “#5794F2”,
“field”: “arc__memory”
“targets”: [
“dataset”: “Users”,
“datasource”: {
“type”: “mssql”,
“editorMode”: “code”,
“format”: “table”,
“rawQuery”: true,
“rawSql”: “SELECT TOP (1000) [id] as id\r\n      ,[title] as title\r\n      ,[sub_title] as subTitle\r\n      ,[cpu] as mainStat\r\n      ,[memory] as SecondaryStat\r\n      ,[c_disk_size] as arc__cpu\r\n      ,[d] as arc__memory\r\n      ,[detail]\r\n  FROM [Users].[dbo].[Servers]\r\n”,
“refId”: “Node”,
“sql”: {
“columns”: [
“parameters”: [
“name”: “id”,
“type”: “functionParameter”
“type”: “function”
“parameters”: [
“name”: “title”,
“type”: “function”
“parameters”: [
“name”: “sub_title”,
“type”: “function”
“parameters”: [
“name”: “cpu”,
“type”: “function”
“parameters”: [
“name”: “memory”,
“type”: “function”
“parameters”: [
“name”: “c_disk_size”,
“type”: “function”
“parameters”: [
“name”: “d”,
“type”: “function”
“parameters”: [
“name”: “c_disk_size_color”,
“type”: “function”
“parameters”: [
“name”: “d_color”,
“type”: “function”
“parameters”: [
“name”: “detail”,
“type”: “function”
“groupBy”: [
“property”: {
“type”: “string”
“type”: “groupBy”
“limit”: 50
“table”: “dbo.Servers”
“dataset”: “Users”,
“datasource”: {
“type”: “mssql”,
“format”: “table”,
“hide”: false,
“rawQuery”: true,
“rawSql”: “SELECT TOP (1000) [id] \r\n      ,[source]\r\n      ,[target]\r\n      ,[main_stat] as mainStat\r\n      ,[secondary_stat] as secondaryStat\r\n      ,[detail_one] as detail__1\r\n  FROM [Users].[dbo].[Edge]\r\n”,
“refId”: “Edge”,
“sql”: {
“columns”: [
“parameters”: [
“name”: “id”,
“type”: “function”
“parameters”: [
“name”: “source”,
“type”: “function”
“parameters”: [
“name”: “target”,
“type”: “function”
“parameters”: [
“name”: “main_stat”,
“type”: “function”
“parameters”: [
“name”: “secondary_stat”,
“type”: “function”
“parameters”: [
“name”: “detail_one”,
“type”: “function”
“groupBy”: [
“property”: {
“type”: “string”
“type”: “groupBy”
“limit”: 50
“table”: “dbo.Edge”
“title”: “Panel Title”,
“type”: “nodeGraph”
Thanks in Advance.
