I would like to let views of a dashboard selectively change the Y-Axis scale using a custom Variable. eg (Linear,Log10). Is there any approach to use variables to set graph parameter like this? Can I include the variable in the json definition of the scale setting?
Same question.
This will be a very useful feature.
I am also interested in this feature.
A related feature is to display two y axes. This is possible with two different metrics on one graph [ref], but it does not seem possible to apply to two axes.
I understand this feature would require adding unit conversions, but if grafana can do timezones then unit conversions should be easy.
