Scale Log/Linear User Control?
We can change the scale by configuring it within the panel, in the axis section, and or by adding an override.
Is there a way to offer a user the ability to change the scale for a metric without going into the panel or dashboard config?
Something similar to how variables can be used to create different selections in your query but for changing scale.
Thx
