tested on v8.2.5 and 9.3.6, CentOS -
Give non editors the chance to set min/max of y-axis via defined variables -
Setting up variables (Y_MIN/Y_MAX) and use them in panel/axis options (as “$Y_MIN”)
- What happened?
For (soft)min/max nothing happened. Label schows the text, but not the value of the variable.
For the panel title (=Y_MIN) it is working!
Min/max settings of axis should take value of variable.
