Grafana v10.0.2 -
I am subscribing to ~ 100 variables from Influx. I want to provide a comparison view where a user can select any combination of variables for visual comparison - e.g. to see and verify dependencies for errors, … -
I created a panel and added all variables. I have hidden all axes to avoid confusion. -
What happened?
When using the same scale for the axes it can hardly be used. The variables with completely different ranges in the same scale lead to non visible small changes in some variables. -
I would like to normalise the data - either in query (I use Influx datasource) or in panel visualisation - to only show 0-100% for each variable - absolute value is not relevant for the user here - its only important to be able to compare different variables properly. -
No -
No -
Did not find any so far…
Any support appreciated ![]()
