Make two series use the same axis/scale
    • Grafana cloud, not sure what version, but it auto-updates
    • I want to compare kills vs deaths on the same axis/scale.
    • I’ve graphed the two series, but they both have their own axis. The deaths are usually a lot lower, but most of the time look higher than kills since the axis scale is so low.
  • What happened?
    • Both series have their own axis
    • I only want one axis
    • Panel JSON:
      Summary
          "id": 1,
          "type": "timeseries",
          "title": "Kills and Deaths",
          "gridPos": {
            "x": 0,
            "y": 0,
            "h": 8,
            "w": 12
          "fieldConfig": {
            "defaults": {
              "custom": {
                "drawStyle": "line",
                "lineInterpolation": "linear",
                "barAlignment": 0,
                "barWidthFactor": 0.6,
                "lineWidth": 3,
                "fillOpacity": 0,
                "gradientMode": "none",
                "spanNulls": false,
                "insertNulls": false,
                "showPoints": "auto",
                "showValues": false,
                "pointSize": 5,
                "stacking": {
                  "mode": "none",
                  "group": "A"
                "axisPlacement": "auto",
                "axisLabel": "",
                "axisColorMode": "text",
                "axisBorderShow": false,
                "scaleDistribution": {
                  "type": "linear"
                "axisCenteredZero": false,
                "hideFrom": {
                  "tooltip": false,
                  "viz": false,
                  "legend": false
                "thresholdsStyle": {
                  "mode": "off"
                "lineStyle": {
                  "fill": "solid"
              "color": {
                "mode": "thresholds",
                "fixedColor": "dark-red"
              "mappings": [
                  "type": "value",
                  "options": {
                    "true": {
                      "color": "green",
                      "index": 0
                    "false": {
                      "color": "dark-red",
                      "index": 1
              "thresholds": {
                "mode": "absolute",
                "steps": [
                    "color": "green",
                    "value": null
            "overrides": [
                "matcher": {
                  "id": "byName",
                  "options": "true"
                "properties": [
                    "id": "color",
                    "value": {
                      "mode": "fixed",
                      "fixedColor": "dark-green"
                "matcher": {
                  "id": "byName",
                  "options": "false"
                "properties": [
                    "id": "color",
                    "value": {
                      "mode": "fixed",
                      "fixedColor": "red"
          "pluginVersion": "12.4.0-19378664917",
          "targets": [
              "datasource": {
                "type": "criblcloud-search-datasource",
                "uid": "ef55hyzh2al8ga"
              "query": "dataset=\"logs\" kill=* | timestats count() by kill",
              "refId": "A",
              "type": "adhoc"
          "datasource": {
          "options": {
            "tooltip": {
              "mode": "single",
              "sort": "none",
              "hideZeros": false
            "legend": {
              "showLegend": true,
              "displayMode": "list",
              "placement": "bottom",
              "calcs": []
            "timezone": [
              "browser"
    • No errors
    • I looked through many community topics where people mention the same thing. The solutions they have don’t work for me.
I have no axis overrides, hiding an axis doesn’t actually force it to use the other axis’ scale, and there doesn’t seem to be an override to completely remove an axis.
The green line is kills and the red line is deaths. As you can see, sometime the red line is above the green line, even though the actual value is a lot lower.
