Data does not match Y axis values
I’m running grafana-5.3.4 on a Linux system, which is querying an InfluxDB database. One of the graphs that I’m using renders data from 2 different queries. One of the queries if fine (temperature). However, the other query (AQI) does not line up with the Y axis values correctly. This image illustrates the problem:
Is this a bug, or am I potentially doing something wrong?
thanks!
I have the same problem. (but when displaying only one graph (for ex, by clicking on the green “free” graph label on the right, the Y axis becomes correct. Only when the two graphs are displayed at once , the Y Axis is displayed with wrong values …
Do you have a solution / Do you remember your solution (I see it was long time ago …)
It appears this problem still exists. My data is in the range of 70-80, and the axis labels go from ~70-160. Wonder if it’s a coincidence that the upper limit is doubled.
I had the exact same issue. For me the solution was to set “Stack series” from “normal” to “off” in the options. Otherwise the data of the first plot get added to the data of the second plot, I think.
