I have a dashboard that uses Influxdb as a source and has variables for the host.
One of the graphs shows a count (whole number) and another data point which is time-based (how much time it took in seconds e.g. 0.031415.) The units are set for left and right y-axis (none and seconds) and the response time is set to the right y-axis. When I display values for 1 item, it shows it in ms or s, etc. When I have 2 items, the first item has units, the 2nd item doesn’t show any units.
Am I missing something? I’m still learning all the nuances…
I’ve upgraded my instance of grafana to 5.1.0 and I’m still having the same issue. Anything I need to do to “refresh” or delete a cache or something like that?
I wasn’t able to do anything on play.grafana.com because I’m not a member of a group … if you can give me permissions, I’m sure I can do something on there to replicate the data I’m using.
I figured out what the issue is after trying to reproduce in play.grafana.org. It seems that when I set the Y-axis for the 2nd value, I had originally only one probe showing. This is what got selected for the Series specific overrides and therefore I only have that one probes value for the y-axis. By changing it to a regular expression which encompasses all the values possible for that series, it now shows everything correctly.
From a UI perspective, it would be more intuitive to have an “axis” option in the query. That way, you can select that field to be on the Right Y-Axis in the query itself. It would be easier to figure out which part of the query or if you have multiple queries/sources, which one of those, is plotted against which Right and Left Y-axes.
