Hi folks, first post, hope I’m following the rules! Thank you!
What Grafana version and what operating system are you using? 9.2.10 on REL8
What are you trying to achieve? Trying to use values from my datasource (JSON) in time series panel legend
How are you trying to achieve it? As field overrides
What happened? Displaying {{fs_name}} instead of the filesystem name from the datasource
What did you expect to happen? Display /opt - as an example
Can you copy/paste the configuration(s) that you are having problems with? I have a screen shot
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. n/a
Did you follow any online instructions? If so, what is the URL? no
