Unable to see metric values as legend in time-series
  • I’m using Grafana v10.4.1 (d94d597d847c05085542c29dfad6b3f469cc77e1)
    I’m trying to create a time-series visualization panel with and legend to be able to used as clickable filters
    Using MSSQL data source to fetch data with the bellow query:
SELECT
  $__timeGroup(UtcDate, '1s') as time,
  COUNT(hash) as value,
  ClientId as metric
FROM
  AqsCscClientSignRequests
WHERE
  Action = 0
  AND
  $__timeFilter(UtcDate)
  AND
  ClientId in ($client)
GROUP BY
  ClientId, $__timeGroup(UtcDate, '1s')
    I was expecting to have the values of distinct metric as legend options.
Hello @ngmathiou,
Welcome to the forum,
if you where expecting something like this:
You can achieve it by using the tag of your measurement:
Where vm_name and host are two tag from my measurement proxmox.
The Last* option you see come from the the legend parameter.
Regards
Right above the query you will see a Format drop down, change that to time series like @codi639 has it on screen shot
Oh great! Thank you very much that did the trick to get the results I wanted!
