Hello All,
I am very new to Grafana, struggling to make my first dashboard on MSSQL. I have written following code for making my first time series panel.
SELECT
$__timeEpoch(T_DATE),
VALUE_NAME as value,
PARAMETER column> as metric
FROM
TB_TEST
WHERE
$__timeFilter(T_DATE)
ORDER BY
T_DATE ASC
but getting error. Can someone guide me please.
Welcome
Would help if you posted the error as we do not have access to your grafana ![]()
Thanks a lot for your response, Since I am new to Grafana getting stuck in every step. However I would be of great help if you can support me in following two points.
- I have made a time series plot using following code
“SELECT
VALUE as value,
PARAMETER as metric
FROM
TB_TEST
WHERE
$__timeFilter(T_DATE) AND PARAMETER = ‘ENG_RPM’
ORDER BY
T_DATE ASC”
Now I want to make this PARAMETER field dynamic, e.g there should be a dropdown panel where user will select any parameter of their choice and same will be plotted. - I have used a stat visualization to show total number of distinct records in a column using following code
SELECT COUNT(DISTINCT(ENGINE_NO)) from TB_TEST
it is working fine if we use format as Table but if we want to use format as time series it is not working. As a result irrespective of my time window selection the stat value is remaining unchanged.
Thanks
i guess you resolved your original issue?
- wherever ENG_RPM is coming from you need to create a variable that queries the source of that data or create a manual list. for that read this
Templates and variables | Grafana documentation -
there is no time column to plot here so time series wont work
