I am running Grafana 8.5 . I can upgrade but the question most likely stands for Grafana 9 aswell.
I have a datasource that returns simple data that contains ‘label value’: (I get data from Azure Monitor ):
The clientId field is the one I want my legend labels to be in the series panel .Is not high in cardinality (~15 but varies over time) .
I have seen in Prometheus datasource when multiple labels are returned they are different dataframes in the inspector , in my case it is only one dataframe . I tried to see if there is a transformation to split the dataframe by column into multiple ones just to show the legend values but couldn’t find a way.
Basically I want my data to be seen as different dataframes by the panel based on data column . Is it possible ?
