Graph Panel with more than 2 Legend format labels
I’m using Grafana 5.1.2 with a Prometheus data source. In my data sets I have data series with 5 labels. In the Graph Panel I put 3 of the labels in the “Legend format” and nothing shows up as far as data. What’s odd is if I only specify 2 of the labels it shows up fine. Is there something I’m missing to get 3 labels to show up?
Nevermind, I found the problem. In the edit view you need to click the “view” button twice. The first time it clears the current graph/legend data and the 2nd time it repopulates the graph.
