How can we select multiple labels values from the Labels to fields section to show in the Legend.
Currently I am trying to show host,if_name,if_desc as part of the legend for the my time-series data view. But I am getting option to select only one label.
grafana/grafana:8.5.5
- What are you trying to achieve?
Modify the legend with multiple label values
- How are you trying to achieve it?
By using the Labels to fields option from transforms
- What happened?
I can only select one label, How to select multiple labels
Multiple labels to show in the legend
- Can you copy/paste the configuration(s) that you are having problems with?
No -
