Grafana 11.0
Ubuntu 22.04 LTS -
Repeat a time-series query for each value/label pair of a multi-value variable, and show a legend that has the label name of the variables. -
I have created a variable with a query to retrieve a list of IP addresses and a text label for each, I have used named capture groups to associate the two correctly. I then created a timeseries graph with the following settings:
SELECT “sensor” FROM “sensor” WHERE (“hostname” =~ /^$ipeltek$/ AND “sensor_descr” = ‘MainsVolt 1’) AND $timeFilter GROUP BY “hostname”::tag
What happened?
The graph displays correctly, however the legend is only showing the value of the variable (in this case it is an IP address) instead of the text label (which should be a name) -
The legend to show the correct variable label instead of the values -
Here is my Variable config:
Here is my query and resulting graph:
Please note in the graph above, the legend shows a list of IP addresses, but instead, I want it to show the names of the variables (as shown in the variable definition screenshot)
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No errors - Did you follow any online instructions? If so, what is the URL?
No guides followed as I could not find any that suited what I was trying to do but I asked for advice in the Facebook group
