"Time Range" missing?
Hi all, hopefully something really dumb… I’m trying to get different time ranges for different graph panels on a single dashboard. I’m sure I’m missing something obvious, According to the docs, I should see this:
However, what I actually see is this:
in the queries tab, at the end
Got it, thanks. Is there any other docs I should be following?
No, there is not, the images of the documentation must be updated, but it is not a process as simple as the others.
can you guide me because I am still lost :slight_smile:
Hello mouthpiec!
You can find more information/guidance here:
thanks … sorted :slight_smile:
How did you solve it? I can find only “Min time interval”, “Relative time” and “Time shift” at the bottom of queries tab.2019-10-10%2013_41_29
update relative time value. For example if you need a graph showing the last week, update relative time to 1w
Ok, thanks. I was expecting to be able to set a custom range.
Is there an option to update relative time not backward but forward? Make “time shift” +10h. So far it always makes “time shift” to -10h
