Panel Custom Time Interval
I saw some screenshots of panels that do show a title in the upper right corner with a different time frame than that on Grafana main toolbar.
How can I achieve this in e.g. a graph panel? Precisely, I’m trying to display data from last month, starting from the first of the previous month until the end.
As already said, this panel should not be influenced by the main time selection at all.
Michael
Hello michifr! Unfortunately, this is currently not possible. However, I have found this workaround solution that might be useful for you and can help you. :slightly_smiling_face:
Regarding the screenshots of panels that do show a title in the upper right corner with a different time frame than that on Grafana main toolbar - yes you can override the panel time range, however you can only override the dashboard time with relative time ranges. Absolute/semi-relative time ranges are not available.
See example below, where I set 1 month relative time override:
Hi Ivana,
thanks for reply!
That’s how I’m doing it right now, however, as you can guess, it’s not exactly e.g. the previous month but a month back starting from the current date.
