Template Service Error when using Discrete Visualization
    v6.7.4 Ubuntu 21.10 on my home PC
    I would like to view a dashboard that shows discrete (ON/OFF) data from various tables.
    OpenHAB stores ON/OFF entries in a table in a MySQL db on my NAS. I query it with grafana, format as Table, and select the “Discrete” visualization.
  • What happened?
    When I first setup the visualization, it generally works as expected. But, if I start changing the time filter to different values, then I get the following error message:
Note that this doesn’t happen ALL the time. About 10% of the time, it works as expected. I have not yet been able to correlate the failure or success with anything else - it appears random to me right now.
    I expect it to show me my data.
    Just the discrete plugin docs for displaying data.
    Discrete plugin for Grafana | Grafana Labs
bump
nobody knows? Does this only happen to me?
It is an error in your dashboard variable defitions, not in your panel query.
Yup, it was because my version was old.
I was snap to install grafana, and the latest/stable channel appears stuck at v6.7.4. there is another channel called 20.04/stable which brought me up to 7.2.0 and solved the problem.
There are later versions available in the various pre-release channels on snap, but the snap package is clearly lagging quite a bit behind the versions available for download.
Do you have to use snap?
