Table Row Color
Hi All,
I am unable to color my rows on the basis of value coming in a single column. Is there a way to do that ?
I am using the V7.3.1
Appreciate your help!!!
Thanks,
Shubham
Hi @shubham2712,
The documentation on the table panel will help you color rows the way you’d like.
You should also check out this nice table on the play.grafana.org sandbox site.
Here’s a screenshot of that panel. I think it’s close to what you want to achieve.
Although you can use thresholds to colour cells, I think the OP wanted a method to colour an entire row based on a specified field.
I don’t think the table panel supports coloured rows.
yup correct !!!
I want the whole row colored rather than cell based :frowning:
@codlord is correct, @shubham2712. This feature was supported in older versions of Grafana but is currently not available. There is a workaround to use the old table panel, but I think this might be on the roadmap for Grafana 8. I’ll ask the team and get the details. In the meantime, here is the workaround:
Open your panel JSON.
Find the line reading: "type": "table",
Change the line to: "type": "table-old",
This will load the old Angular table visualization.
Now edit your query and scroll down to Panel ==> Options ==> Thresholds ==> Color Mode. Select Row. Now you can colorize an entire row!
More soon on whether or not this feature is returning.
@shubham2712 ,
I spoke with the frontend team and I don’t think this feature will get implemented for the Grafana V8 release, but it is now on our backlog :+1:
Hi @anon70503803 can we create a pivot table using Grafana ?
I am unable to do that!!! Can you please help?
Hi @shubham2712,
you might be able to achieve what you want, but it probably depends on the details of your situation. For instance: what is your datasource and what are you trying to achieve?
I would read these two related topics and see if they help you transform your data how you’d like:
~m
I also ran into this question of how to color a whole row based on a property of a column value.
And see
@anon70503803 wrote
I spoke with the front-end team and I don’t think this feature will get implemented for the Grafana V8 release
This is now the third time I read
  • was available in Table(old)
  • but is not available in the current Table
upvote this feature request:
