Table visualization in Grafana coloring feature to entire row based on on column value
Dear Team,
I need some support on the below implementation and possibility in Grafana Table visualisation.
Table visualization in Grafana coloring feature to entire row, based on on column value.
Thanks & Regards,
Chandra
@chandranallam I can’t think of a way to colorize an entire row. You should search this forum for older threads–I know this has come up before.
Then I would advise that you make a feature request in the grafana/grafana repo.
