I m not able to color a particular row in Table panel
  • Grafana: v.11.4.0, operating system 11
  • I m trying to get the color for particular row in Table panel it should be colored on the bases for Thresholds
  • i have tried value mapping, thresholds and transform
  • What happened?
  • only columns are getting colored not row
  • that particular row should get colored
Can you give a specific example?
You can use the Business table plugin or the vanilla table with the option “apply to entire row”
i want to color that TOTAL row in Grafana
conditions are different for every month so color should be changed according to that condition
AH ok, a color for every cell… have you tried “status history”?
ok forget it, then the hole tabe is colored.
Sounds like a task for Business Charts- / Business Text-Plugin…
Like @joachimschiewek recommended business text is best suited for this see below
