What Grafana version and what operating system are you using? Grafana version 8 OS centos 8
What are you trying to achieve? Need to colour whole row based on threshold
How are you trying to achieve it? Using Table panel
What happened? Currently only column cell is coloured.
What did you expect to happen? We need to colour the whole row based on thresholds.
Can you copy/paste the configuration(s) that you are having problems with? NA
@vram2694 I don’t think that row-based value-mapping is possible, but I know that you are not the only one to want this feature.
I would suggest starting a discussion for the enhancement in the repo. This is the best way to get traction for new features:
