I’m having issues with the Table panel when I try to color row based on value in cell, see below.
I’m running Grafana in a docker container using the latest image providing grafana version 11.4.0-209562. -
I would like to color whole row based on value in a column. -
The data comes over a websocket to the panel, using the websocket plugin from plugins catalogue. -
What happened?
I’m not able to see the ‘Color row’-option:
I do not see anything in my logs.
Does anyone have a clue to why this happens?
Any help is highly appreciated!
